TwinTurbo.NET: Nissan 300ZX forum - Re: cleaning engine after blow hg/coolant oil mix
Subject Re: cleaning engine after blow hg/coolant oil mix
Posted by Zuberman on May 13, 2015 at 12:19 AM
  This message has been viewed 261 times.
In Reply To cleaning engine after blow hg/coolant oil mix posted by LivinTheDream on May 12, 2015 at 07:37 PM
Message Maybe clean with the brake-part cleaner, let evaporate, and then dribble some oil wherever you sprayed?
Assembly lube on the cam-lobes and wherever else appropriate.
Even after that, I would do an engine flush.
